Tell us about your projects...
Stanga
Been thanked: 2 times
Re: Tell us about your projects...
Post by Stanga »
Unfortunately for me I lost out on the chance to take part in this thread and qualify to win a free copy of FC5 partly due to delays in a code issue in FC4. See my query on PIC16F88 ADC errors. But I managed to modify the code and have finally managed to launch the product onto the market, but 6 months later.
It is a HIFI DAC (digital to analogue converter) that is software and hardware controlled. The product itself is known as the Beresford Bushmaster DAC. A Google search should bring up my website address and product comments in various forums around the world. The software code was written in FC4, and the functions of interest are:
1. Battery health monitor. The DAC is normally powered via a 12V DC mains connected power supply. It can however also be used with a rechargeable battery. The state of the battery health is monitored via a FC routine and when the battery level approaches 11V a LED starts to blink. This warns the user that the battery needs recharging.
2. AUTO/MANUAL input select. I asked in the Fotias audio preamp thread if such a feature would be of any use for that preamp but after receiving no response I went ahead with developing a routine that ended up in my DAC. The code polls the inputs one by one and upon detection of a valid audio signal it stops searching the other inputs and starts passing the detected and validated audio. When that audio is removed, the DAC reverts back to auto audio search.
3. AUTO LED dimming. This function switches off the LEDS after a few seconds once the DAC has detected an input signal and starts to play. It will also switch off after a few seconds when in AUTO mode but will switch on again for a few seconds and indicate which input has a signal present.
I am working on some code enhancements such as LED brightness adjust and input channel override. The latter is aimed at the likes of SONOS and SKY boxes which hug the inputs with a valid audio command even if they are switched off. This command fools the AUTO function, so a bypass of some sort has become a requirement. The LED brightness adjust only works without any sign of blinking when I use an oscillator above 12MHz. But due to time constraints I have not yet added it to the product that was launched.
I also want to use I2C for some software functions, so I am building a development board to help me with that. The reason I find myself having to build my own development board is because the DAC chip runs off 3.3V, but the FC development boards work off 5V. There is no voltage level shift board in the Matrix range as yet so I can't use any of them to communicate between the DAC chips and the MATRIX boards directly. I wish that Matrix did have at least one board that could be used for I2C and SPI development and work off 3.3V or 5V. I did find such a board on eBay that is made by BYVAC. It has proven to be extremely useful to me so far.
StanleyB ( yes THE StanleyB from internet forums fame)
Steve001
Has thanked: 460 times
Been thanked: 523 times
Post by Steve001 »
deleted as requested
Steve001
Post by Steve001 »
echase
Has thanked: 49 times
Re: Students projets at INSA LYON
Post by echase »
benp wrote: Segway like vehicle monitoring on a wifi tablet.
Here is another Segway like project. No done by me and not using Flowcode as far as I know, but you could take their published C Code, put it into Flowcode and modify it. It uses a DSP PIC. http://www.scribd.com/doc/76661790/10/Microcontroller
benp
Has thanked: 3 times
Been thanked: 41 times
Post by benp »
THe Segway was updated in 2012-2013.
It uses Flowcode dsPIC and EBlocks
More information here:
http://www.matrixmultimedia.com/mmforum ... 29&t=10251
And the vidéo here:
[/youtube]
INSA 1er cycle GCP projects with or without eblocks:
http://www.youtube.com/user/INSAgcp
