Frequency counter 35 Mhz
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Re: Frequency counter 35 Mhz
Post by Jan Lichtenbelt »
The frequency counter Version 4.1 is special to show a frequency on a LCD screen. This program is not helpful if you want to use the (value of) frequency for other reasons.
This version 5 is a special macro to measure the frequency. Because values to 2 MHz are possible, the frequency variable will be Ulong (32 bits).
The accuracy can be set between 1 to 4 digits. The macro can show, if LCD is set, a warning for long sampling times and the frequency measured.
Kind regards
Jan Lichtenbelt
Frequency_Counter.fcm
(15.99 KiB) Downloaded 399 times
High Frequency Counter V5.fcf
(24.73 KiB) Downloaded 421 times
