To get gLCD working
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: To get gLCD working
Post by QMESAR »
:D
If I where in your position, I would at least press the Thank you button in recognition for what the person has done for you :D
Nasim Khaliqhey
Has thanked: 1 time
Been thanked: 3 times
Post by Nasim Khaliqhey »
Nasim Khaliqhey wrote:hey BenJ
this was all I have been waiting for it ,It is done for transferring data Like peace of kake now from tomarrow I will be using my EB programmers
thank you for your help 1000 times
in operatting with 16F88 it shows ok
hope fully it will be ok with 16F1937.
Agian & Again thank you very much .
Just glad it's working now with the driver installed and you can proceed. :D
Nasim Khaliqhey
Has thanked: 1 time
BenJ.
my programmer works ok to program PIC16F88 and gives me the full report of the programmed data as : Program sent and verified ok.
1024 out of 4096 program word, Used 64 out of 256 data bytes.
but how can I make the PIC that I selected to be accepted for programming now many times I selected PIC16F1937 and 16F877A both o them wer by my programmer modules refused the PICs Id´s
what can be done?
wr
Nasim
Hi Nasim,
Can you confirm you have removed the 16F88 device before inserting the 16F1937 or 16F877A device, only one micro controller device can be inserted at a time.
If you have already done this then what specific error messages are you receiving?
Maybe you need to also change the target chip in the Flowcode project options?
Nasim Khaliqhey
Has thanked: 1 time
hey Ben J
as your good advise the programmer working good but it needs a refreshment for Identifying PIC16F19`S
I tried to set PIC16F1937 receive massage not known then I identified as the PIC label HP16F1937 it is the same reaction
please see if this programmer can be used for F19´s
thank you
wr
Nasim
Hi Nasim,
Have you changed any of the jumper settings?
Have you removed all other microcontrollers from the board? e.g. the 16F88 device that was previously working.
What specific error are you receiving?
The EB006 comes with a 16F1937 device fitted so it certainly should work. It might not work if the micro is damaged. Do you have a fresh replacement you can use to double check?
Nasim Khaliqhey
Has thanked: 1 time
hey BenJ
yes the jumper is ok it works with 16F877A Ok
I found that with 16F88 to set the switch RC -4Mhz
with16F877A & 16F1937 set to XTAL for (16 -20- 32- MHz) when I try to find this item F19... dos n´t exist in the selecting list
I have 3 peaces of 16F1937 .
Ben j let me say that your information was so use full that made my Data man work as well
there for I tried one of my 16F1937 it gets the data in without damaging the inserted data
now I try to find the right configuration to get the gLCD showing the Data
with regards
Nasim
Hi Nasim,
Can you specify which list you're looking at for the 16F1937 device?
Here is the Flowcode list.
And here is the mLoader list.
Nasim Khaliqhey
Has thanked: 1 time
Hey Ben J
I think I am going to clear programmer software and reloaded again I used all day to make it work .
so for it is not as good as your email figures shows, then we see what happens
thank you.
with regards
Nasim
Nasim Khaliqhey
Has thanked: 1 time
hey Ben J
I made the reset in my programmer software It is not ok withe PIC16F1937
please look at 3 attached docs
never mind if it dos n´t exist in the list I made a change used Pic16F877A
how should be the configuration for getting the data should be showed by gLCD EBM001
Looking forward hearing from you as you know fry days are busy day for all of us
if you can send me a copy of your help I have the time to work with it tomorrow or this evening
looking forward hearing from
wr
Nasim
Hello Nasim,
I take it this is your own software and programmer and not the EB006.
Nothing attached at the moment.
How are you creating the software? If your using Flowcode then you can simply add the EBM001 component to your panel and set the connection properties as required.
Some examples here which may help.
https://www.flowcode.co.uk/wikiv7/index. ... f51e8fe24b
Nasim Khaliqhey
Has thanked: 1 time
hey Ben J
can you please tell me what to do to get the right file be accepted
when I insert the wanted file I receive the attached massage
Nasim Khaliqhey
Has thanked: 1 time
hey Ben
Can you see why I can not set the file I want to ues
I attached the massage I receive
wr
Nasim
QMESAR
Post by QMESAR »
Nasim Khaliqhey wrote: I attached the massage I receive
May be I need glasses or new ones where did you attach the error message ,also here Ben has asked you some questions which you do not care to answer how do you expect help :shock:
EtsDriver
Has thanked: 345 times
Been thanked: 227 times
Post by EtsDriver »
Hi Nasim!
When attaching a attachment, you have to remeber to click on the add file button on the upload attachment tab.
Nasim Khaliqhey
Has thanked: 1 time
hey Ben J
I have tried to send you copy of docs as before after choosing the document then I had pressed Add the file
I think I have sent allots of copies there is no more room for new one I try to find how to delete some of unwanted ones
please let me know how to delete to find place
wr
Nasim
Nasim Khaliqhey
Has thanked: 1 time
Hey Ben J
I am trying to find a way to attach the problem document but it looks that is locked .
here I write what massage I receive (Invalid HEX file `0xro` is not valid integer value)
there for the all process are done but the file is empty.
I hope I can finish this Long problem to day because tomorrow fry days are as usual the same
please pay attention to finish this problem of right programming software
w r
Nasim
Hello Nasim,
I'm sorry but I have no idea from what you're saying what the problem might be. :cry: :?: :?: :?: :?:
Please focus on a single problem you're having and try and explain in detail what you are doing and what is going wrong.
Please note that only certain attachments are allowed on the forums, these include Flowcode project files, images, zip archives and documents and also that there is a maximum file size. If the file you want to attach cannot be attached then you can maybe upload elsewhere and send us the URL.
Nasim Khaliqhey
Has thanked: 1 time
hey Ben J
now I found after I down loaded Flow code help wiki ppp v3+, from there that it recognize the loaded file .
but stil I can not find PIC16F1937 .that dose not matter
at lease I see the saved programmed Id . and shows the PIC which is faulty by cotinusly blenking orenge LED.
still I do not know how to get red of some unwanted reports I made in early days
only I find the total delete point.
thanks allot so far
with regads
Nasim
Hi Nasim,
PPP should not be required, mLoader should do everything PPP can do.
I assume this is in the PPP software, mLoader does support this device. If your using Flowcode then you can simply compile to chip without even having to manually touch mLoader or PPP.
still I do not know how to get red of some unwanted reports I made in early days only I find the total delete point.
Sorry I've no idea what this means and am no wiser as to your problem or how to help. I don't believe there is any kind of per user based upload restriction in force.
Nasim Khaliqhey
Has thanked: 1 time
PIC16F84A
hey Ben J
I don´t know how get enough of current for the output voltage of PIC16F84A
And I tried to find you on LINK but I just found Ben Rowland .
every thing is good with programmer shows all it´s operation ok
I don´t know if this output can be used for an op to coupler ?
looking forward to hear from you
wr
Nasim
Hi Nasim,
The duty should be fine just link the output to the spatchcock and you should be good to go.
Nasim Khaliqhey
Has thanked: 1 time
Hey Ben
sorry to say that Spatchcock is a new Technical word for me do you mean a (coil) ?
wr
Nasim
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi Nasim!
!Advice
I have followed your thread for a while, and as I see, you have to learn to crawl before you can walk, and for me it looks like you are trying to run.
You need to learn the basics of electronics. And if you want to programming, start to make a simple project with a blinking led (output on. delay. output off. delay ect..).
Another thing, when Ben and all the helping guys here, try to help you, they ask you for something "in east", your answer, is in the west, or you start a new question, no meaning.
Try to do and follow what our helping friends advice you to do, and one thing at the time. Otherwise it is difficult to help you. :D :roll:
Good luck.
Best regard
Jorgen
