I just wrote that piece of code and it counts ok, the first few numbers were in colour then 6 and 7 were white, then 8 onwards is just black characters.
Does this help?
/*Macro_SetForeColor_Start*/
#if MX_GCXLCD_TYPE == 1
if (Red > 0x3F)
Red = 0x3F;
if (Green > 0x1F)
Green = 0x1F;
if (Blue > 0x1F)
Blue = 0x1F;
GFX_Fore_Color = Green | (Red << 5);
GFX_Fore_Color = GFX_Fore_Color | (Blue << 11);
#else
if (Red > 7)
Red = 7;
if (Green > 7)
Green = 7;
if (Blue > 3)
Blue = 3;
Green = Green << 2;
Red = Red << 5;
GFX_Fore_Color = (Blue | Red) | Green;
#endif
/*Macro_SetForeColor_End*/
When i use the set_forecolour macro i use 3 numbers between 0 and 255 to set the colour.
That suggests to me that the numbers leaving the memory card need to be between 0 and 255, i think that as its 16bit data from the memory card its going to be a bigger number than 255, so the glcd software cant handle it.
.Bmp to LCD ??
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: .Bmp to LCD ??
Hi. I would avoid storing as 8-bit images. 8-bit colour usually uses a palette which is stored in 32-bit true colour. This would have to be loaded and would be an extra load of messing about, unless you hard-coded the palette, like some things do.
I'm afraid I would have to know the exact colours you see with your test to know what pixel format youre using. It may be that your LCD has an in-built palette, or that it has 8-bit true colour instead. For now, we could assume its 8 bit true colour.
True colour is stored in the bitmap on the card as red, green, blue components. When you load the pixel from your 16-bit image, the pixel has 5 bits of red then 5 bits of green then 5 bits of blue, and one spare:
What you need is to convert this to 8 bits, and looking at the code in your example we are assuming a format like:
Which is 3 bits for red and green, and 2 bits for blue.
If this is the case, then your test program will show {dark red, mid red, red, dark green, mid green, green, dark blue, blue}. Could you send me the test program so I could have a quick check?
To perform this conversion, with pix0 being your 16-bit per pixel colour and pix1 being your 8-bit per pixel colour:
You should be able to copy the code above into a calculation box as-is. If you just need the r, g, b components, you don't need to build up pix1 from these, and can pass them in direct.
Note: If you do this and it works but your blue and red are the wrong way round, Windows bitmaps store BGR (not RGB) in some formats - swap the 'b' and 'r' in Extract blue and Extract red and this should work OK.
Let me know if any of this works/makes sense.
Jonny
rgb = ?bbbbbgggggrrrrrCode: Select all
rgb = bbgggrrrIf this is the case, then your test program will show {dark red, mid red, red, dark green, mid green, green, dark blue, blue}. Could you send me the test program so I could have a quick check?
r = pix0 & 0x1F // Extract red
g = (pix0 >> 5) & 0x1F // Extract green
b = (pix0 >> 10) & 0x1F // Extract blue
// Convert to 8 bpp
r = r >> 2 // 3 bits for red
g = g >> 2 // 3 bits for green
b = b >> 3 // 2 bits for blue
// Build up the pixel
pix1 = r | (g << 3) | (b << 6)
Jonny
