Dual CAN ports on the 30G6012A?
Posted: Mon Feb 13, 2012 8:43 am
by beambase
I am doing a project on a 30F6012A with FC ds24 version 4.3.
Is it possible to enable both the internal CAN controllers that is built in to the 30F6012A? I have CAN1 successfuly working.
Re: Dual CAN ports on the 30G6012A?
Posted: Mon Feb 13, 2012 2:21 pm
This is not something Flowcode can do directly but if your C knowledge is ok then you may be able to take the code for channel 1 and use this to compile together your own channel 2 code. In the most case it will be taking register names eg xxx1xxx and renaming to xxx2xxx.
