programmer Profil
Posted: Sun Apr 01, 2012 12:01 pm
by Frank123
I use Flowcode V4 with Pickit V2 or pdfusb. Is it possible to create a profile to quickly change programmer ?
Thank's
Re: programmer Profil
Posted: Sun Apr 01, 2012 12:52 pm
Hi Frank,
Steve covered that here:
http://www.matrixmultimedia.com/mmforum ... 34&#p16134
I have .reg files saved for hitec, boostC and Pickit V2
So method works very well.
If using V5, this has been implemented.
Save as many different programmers as you want, then just select programmer from a drop down box:
(127.47 KiB) Downloaded 1137 times
Note: Programmers are not built in, you need to initially set them up first.
Posted: Sun Apr 01, 2012 12:58 pm
by Frank123
Thank's medelec35.
