Autodetect picmicro
Posted: Sun Jun 17, 2012 1:20 pm
I am using my newly acquired dspic/pic24 board. When I am using the autodetect PICmicro function I get a message "USB cable not connected, continue, yes, no"
However the board work when I use the "EB064_B_pic16" factory test routine to program the dspic30F2011
Also if I try to reproduce the factory test routine nothing work and I get the following warning:
File sent with 1 warnings:
1: CONFIG failed to erase bits at [1f00000]
Contents of file are:
02 43 3F 00 B3 87 FF FF FF FF FF FF 03 40
Contents of chip are:
02 43 3F 00 B3 87 0F 31 0F 33 07 00 03 40
Return code = 0
FINISHED
Gerhard
Return code = 0
FINISHED
Gerhard
