c in fllowwcode4 not work
katef
Post by katef »
hi i try to run the code in the attachment below the embedde c code not work plz help me
thanks a lot
2. Embedding C and Assembler code.FCF
(10.5 KiB) Downloaded 553 times
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: c in fllowwcode4 not work
Post by JohnCrow »
Sorry I dont have time tonight to try your program on hardware, but do you mean it wont work on hardware or in simulation ?
It is not possible to simulate C icon in FC
Also are you using the free version, as this only allows 4 lines of code per C Icon.(Not sure if comments count as lines of code) but this could also be a problem.
See link below for details of limitations of Free edition
http://www.matrixmultimedia.com/mmforum ... m.php?f=49
If you can give a bit more details as to the error you are getting it will help is help you.
