text from the keyboard
Posted: Tue Oct 23, 2012 5:58 pm
by donald
Hello all,
How can I insert text from the keyboard and viewed on the display.
Thank you in advance!
Re: text from the keyboard
Posted: Wed Oct 24, 2012 12:43 am
Hi Donald,
I have created a flowchart which will allow you to add letters A to Z, add a space and delete any entered letters:
At the moment you need to press a key up to 3 times (just like on phones) then press Hash to enter.
For improved speed it may be better to have a predetermined time elapse then key is auto entered. Then you will not need to press # to enter.
I did not have much time tonight so did not do the time out method.
If you would like to use the timer method, I will see if I can get the chance to do that tomorrow (Wednesday)
Posted: Wed Oct 24, 2012 3:33 am
by donald
It is very good, but if it can use the delay, it is welcome.
And there is a little problem, use next row.
Thanks very much!
Posted: Wed Oct 24, 2012 11:52 pm
Hi donald,
I have added the following:
timer, extra line, Numbers 0 to 9 and When you press space button an underscore briefly appears in the place a char will appear when keypad is next pressed.
I have done this so if using a few spaces you will not loose position of where next char will appear.
Since next line will automatically be used when top row is filled, the flowchart is more complex since I have left in the char delete button.
This has not been tested on hardware, so I'm not sure if auto entry has ideal timeout or not.
If you want more or less time, I can sort that easily
Currently it's set for 1.2 seconds
Posted: Thu Oct 25, 2012 4:04 pm
by donald
Posted: Thu Oct 25, 2012 6:42 pm
thanks and your welcome.
Glad you like it!
Posted: Sat Oct 27, 2012 12:23 pm
by donald
Hello all,
Sir Martin, written texts can be saved? You can transfer in a micro SD
and then updated?
Thanks in advance!
Posted: Sat Nov 03, 2012 1:07 am
Hi Donald,
I have not got Micro SD Eblock, So I can't create a flowchart, as no means of testing it works.
So what I have done is altered flow chart so the letters/numbers are stored in a string variable called Letter_Storage as well as displayed on LCD.
Delete function also deletes char from Letter_Storage variable as well.
Posted: Sun Nov 04, 2012 1:51 pm
donald wrote:transfer in a micro SD
Hi Donald,
Just had a thought.
Micro SD (FAT Component) will not be enabled with free version of Flowcode V5
So you will need to upgrade to Professional for that component to work.
Posted: Sun Nov 04, 2012 4:02 pm
by donald
Yes indeed i can not. But it is possible that help me with a flowchart and a hex ?
Must say that I always helped me your solutions for the resolution to understand and develop different schemas flochart.
Now for the holidays I think that purchasing Professional license of the program.
