Unable to compile to hex...
Posted: Fri Nov 09, 2012 9:18 pm
by TezzaMcTezza
I have just upgraded my V5 Home licence to professional but I am now not able to compile my programs to hex.
The compiler message says this at the end:
failure
Return code = -2
Flowcode was unable to assemble the ASM file due to the following errors:
FINISHED
Any ideas?
Re: Unable to compile to hex...
Posted: Fri Nov 09, 2012 9:41 pm
by JohnCrow
Hi Tezza
RAM available:64 bytes, used:115 bytes (179.6%), free:-51 bytes (-79.6%)
If you look at the error message I've posted above, it looks like your code is too big for the device you are trying to use.
You have 64 bytes available but are trying to load 115 bytes.
The fix is to select a PIC with more memory.
Try selecting a larger device in FC and then try compile to hex again.
Posted: Sat Nov 10, 2012 10:19 pm
by JonnyW
Hello. Did this program compile with enough space on your device with Flowcode free version, then failed on Flowcode professional?
Cheers,
Jonny
