USB connection failed
Posted: Thu Nov 15, 2012 9:08 pm
by davet
Hi all, have an eb006 board. I switched my computer off, turned it on again to do some work and the usb connection has failed. In the device manager it says "unknown device" will not recognise the eb006.
Can anyone help?
Dave
Re: USB connection failed
Posted: Thu Nov 15, 2012 10:36 pm
by brandonb
i've fixed simular problems in past with a registry clean on pc
Posted: Fri Nov 16, 2012 12:10 am
by Enamul
You can simply unplug usb cable and re-plug it..and also re-install the usb driver for EB006.
Posted: Fri Nov 16, 2012 10:34 am
Might also be worth a power cycle:
Pull out the PSU and USB cable, re-insert the USB and then the PSU.
