18f66k80 family MCU
Mathy
Has thanked: 30 times
Been thanked: 33 times
18f66k80 family MCU
Post by Mathy »
Hello !
I would like to build some electronic boards with CAN and PWM capabilities and the 18f66k80 family seems to be perfect for that.
Before sending my gerber file to manufacturer, i would like to know if there are any problem with CAN ( internal hardware ), RS232 or PWM macro with this chip family.
thank you for your help :)
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: 18f66k80 family MCU
Post by Enamul »
Have you noticed the internal CAN bug fix here?
http://www.matrixmultimedia.com/mmforum ... 46&t=11126
Also PWM correction..here
http://www.matrixmultimedia.com/mmforum ... 717#p39717
RXINT for hardware RS232 interrupt correction for all chip..
http://www.matrixmultimedia.com/mmforum ... 46&t=11317
If you already been through all this correction, I guess you need to bear in mind for CAN bus that this chip has CAN bus in other pin also than RB2 &3 but I guess only RB2 & 3 is working currently.
Hope this helps :)
Enamul
University of Nottingham
enamul4mm@gmail.com
Mathy
Post by Mathy »
Thank you very much ! Great help !
I have already noticed bug in RXINT interupt but not for PWM and CAN for this one.
Thank you again.
Enamul
Post by Enamul »
You are welcome :D
Enamul
enamul4mm@gmail.com
