Error with RC5 Component
Posted: Thu Nov 22, 2012 12:55 pm
I have a problem with RC5 Component.
My Flowchart run with 16F877A don't with 16F877
I need the Function with the 16F877 (without "A"). Can anybody help me for a running solution?
Here the compiler Message:
Launching the compiler...
c:\program files (x86)\matrix multimedia\flowcode v4\boostc\boostc_pic16_flowcode.exe -v -t PIC16F877 "RC5 Receive.c"
BoostC Optimizing C Compiler Version 7.04 (for PIC16 architecture)
http://www.sourceboost.com
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
RC5 Receive.c
Starting preprocessor: c:\PROGRA~2\MATRIX~1\FLOWCO~1\boostc\pp.exe "RC5 Receive.c" -i c:\PROGRA~2\MATRIX~1\FLOWCO~1\boostc\include -d _PIC16F877 -la -c2 -o "RC5 Receive.pp" -v -d _BOOSTC -d _PIC16 -d _CHAR_INDEX
RC5 Receive.c(212:9): error: unknown identifier 'TMR0IE'
RC5 Receive.c(212:9): error: unexpected '.' operator
RC5 Receive.c(212:2): error: failed to generate expression
RC5 Receive.c(212:2): error: invalid operand 'intcon.TMR0IE'
RC5 Receive.c(212:16): error: failed to generate expression
RC5 Receive.c(230:23): error: unknown identifier 'TMR0IF'
RC5 Receive.c(230:23): error: unexpected '.' operator
RC5 Receive.c(230:16): error: failed to generate expression
RC5 Receive.c(230:16): error: invalid operand 'intcon.TMR0IF'
RC5 Receive.c(230:14): error: failed to generate expression
RC5 Receive.c(231:9): error: unknown identifier 'TMR0IF'
RC5 Receive.c(231:9): error: unexpected '.' operator
RC5 Receive.c(231:2): error: failed to generate expression
RC5 Receive.c(231:2): error: invalid operand 'intcon.TMR0IF'
RC5 Receive.c(231:16): error: failed to generate expression
RC5 Receive.c(531:9): error: unknown identifier 'TMR0IF'
RC5 Receive.c(531:9): error: unexpected '.' operator
RC5 Receive.c(531:2): error: failed to generate expression
RC5 Receive.c(531:2): error: invalid operand 'intcon.TMR0IF'
RC5 Receive.c(531:16): error: failed to generate expression
RC5 Receive.c(532:9): error: unknown identifier 'TMR0IE'
RC5 Receive.c(532:9): error: unexpected '.' operator
RC5 Receive.c(532:2): error: failed to generate expression
RC5 Receive.c(532:2): error: invalid operand 'intcon.TMR0IE'
RC5 Receive.c(532:16): error: failed to generate expression
RC5 Receive.c(550:9): error: unknown identifier 'TMR0IE'
RC5 Receive.c(550:9): error: unexpected '.' operator
RC5 Receive.c(550:2): error: failed to generate expression
RC5 Receive.c(550:2): error: invalid operand 'intcon.TMR0IE'
RC5 Receive.c(550:16): error: failed to generate expression
RC5 Receive.c(880:14): error: unknown identifier 'TMR0IE'
RC5 Receive.c(880:14): error: unexpected '.' operator
RC5 Receive.c(880:7): error: failed to generate expression
RC5 Receive.c(880:7): error: invalid operand 'intcon.TMR0IE'
RC5 Receive.c(880:21): error: failed to generate expression
RC5 Receive.c(880:38): error: unknown identifier 'TMR0IF'
RC5 Receive.c(880:38): error: unexpected '.' operator
RC5 Receive.c(880:31): error: failed to generate expression
RC5 Receive.c(880:31): error: invalid operand 'intcon.TMR0IF'
RC5 Receive.c(880:45): error: failed to generate expression
RC5 Receive.c(880:21): error: invalid operand '=='
RC5 Receive.c(880:45): error: invalid operand '=='
RC5 Receive.c(880:27): error: failed to generate expression
RC5 Receive.c success
failure
Return code = 1
Flowcode konnte den C-Kode des Flussdiagramms nicht kompilieren, da folgende Fehler auftraten:
Wenn Ihr Flussdiagramm C-Kode enthält,überprüfen Sie diesen sorgfältig. Falls das Flussdiagramm keinen C-Kode enthält oder Sie sich sicher sein können, dass dieser Kode fehlerfrei ist, dann wenden Sie sich an den technischen Support.
FINISHED
RC5 Receive.c
failure
Return code = 1
FINISHED
