Fast inverse of square root
Posted: Sun Dec 09, 2012 10:44 am
Hello MM,
As you know sometimes microcontrollers struggle with computation intensive functions, and you want to optimize the code to make life easier for them. So you probably remember the famous hack from Quake ||| to compute the inverse square root of x, if not, here is a remainder how it looks:
I was doing some really complex functions for quaternion calculations and decided to use the famous hack to improve on speed. But this function leads to max error of about 1.75233867·10−3 and average of 1.24792411·10−6.
I did a little bit of googling and found that one crazy kid found better coefficients for the same hack, and it looks like this:
This improves the error quite a lot leading to max of 6.50196699·10−4 and an average of 2.00010826·10−7. So my offer is to incorporate this cool function into FC library just in case someone needs it
Best regards,
Mantas
Edited out swear word as people under 18 could be reading forums..Martin
float Q_rsqrt( float number )
long i;
float x2, y;
const float threehalfs = 1.5F;
x2 = number * 0.5F;
y = number;
i = * ( long * ) &y; // evil floating point bit level hacking
i = 0x5f3759df - ( i >> 1 ); // what the f***?
y = * ( float * ) &i;
y = y * ( threehalfs - ( x2 * y * y ) ); // 1st iteration
// y = y * ( threehalfs - ( x2 * y * y ) ); // 2nd iteration, this can be removed
return y;
}I did a little bit of googling and found that one crazy kid found better coefficients for the same hack, and it looks like this:
float inv_sqrt(float x)
{ union { float f; uint32 u; } y = {x};
y.u = 0x5F1FFFF9ul - (y.u >> 1);
return 0.703952253f * y.f * (2.38924456f - x * y.f * y.f);
}Best regards,
Mantas
