I2C component
Posted: Wed Dec 26, 2012 11:30 pm
by sotos
I would like to know if there is any restriction in numbers of I2C components that I can use in FC 5.4
when I try to use more than 4 I2C component , the compile fails and I receive many error messages . :( :( :(
In previus version of FC ( 4.5 ) I have use 5 I2C component successfuly .
S MAKRIS
Re: I2C component
Posted: Thu Dec 27, 2012 6:46 pm
by Jordy101091
Hi Sotos,
I think you mist understand the component function idea.
If you want to use multiple I2C slave devices you only need one I2C Component.
The key to use multiple I2C slave Devices is to use there internal address to communicate with them.
Hope this help a bit.
Regards Jordy
Re: I2C component
Posted: Fri Dec 28, 2012 11:11 pm
by sotos
Hi JORDY
You're right, it was my mistake to try to use multiply I2C Master componrnts . :oops: :oops: :oops:
Thanks for your answer .
Regards SOTOS
