Hi All,
I met the flowing declaration problem of variables in a rotation right. Let make the problem more clear:
1) take 2 variables A and B, which are declared as 1 byte variable each. Say A=0x01 and B=0x10.
2) I want to place bit 0 of A into bit 7 of B (and all other bits in B shifted to right)
3) The most easy way is in the assembler code like:
Asm
RRF A,F // which places bit 0 of A into the carry bit
RRF B,F // which places the carry bit into bit 7 of B
So far so good. But now in Flowcode 5:
4) The variable A and B will become gbl_FCV_A and gbl_FCV_A in the assembler code. But
asm
RRF gbl_FCV_A,F
RRF glb_FCV_B,F
gives an error that these variabales are unknown
5) The variable A and B will become FCV_A and FCV_A in the C-code. But
asm
RRF FCV_A,F
RRF FCV_B,F
give also the error that these variables are unknown.
In principle 4) is the right assembler code and should be used as such. But it is interpreted as a C-code with wrong variable names.
My question:
Is there and easy/simple solution?
Kind regards
Jan Lichtenbelt
Rotate Right
- Jan Lichtenbelt
- Has thanked: 128 times
- Been thanked: 264 times
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: Rotate Right
this is not right according to Boostc manualasm
RRF gbl_FCV_A,F
RRF glb_FCV_B,F
It should be following which compiles fine..
asm
RRF _FCV_A,F
RRF _FCV_B,F
}To refer to a C variable from inline assembly, simply prefix its name with an
underscore '_'.
// Example showing use of bit tests and labels in inline assembly
#include <system.h>
void foo()
unsigned char i, b;
i = 0;
b = 12;
asm
start:
btfsc _i, 4
goto end
btfss _b, 0
goto iter
iter:
movlw 0
movwf _b
end:
- Jan Lichtenbelt
