I try to get a less as possible program steps.
In Flowcode I have 2 variables A (byte) and B(2 bytes=UInt). Both have to be increased with 1. Thus A=A+1 and B=B+1.
However the assembler codes differ significantly:
1) A=A+1 shows:
INCF gbl_FCV_A, W
MOVWF gbl_FCV_A
is ok, but could be shorter with
INCF gbl_FCV_A, F
2) B=B+1 shows:
MOVF gbl_FCV_B, F
MOVF gbl_FCV_B+D'1', F
INCF gbl_FCV_B, F
BTFSC STATUS,Z
INCF gbl_FCV_B+D'1', F
As far as I see, the first 2 lines only fill the ZERO status flag. These 2 lines does not have sense here. The last 3 lines are essential and can not be shorter.
Do I miss something? What is the reason the bootc put
MOVF gbl_FCV_B, F
these lines in case of an UInt variable?
Kind Regrads
Jan Lichtenbelt
Plus one
- Jan Lichtenbelt
- Has thanked: 128 times
- Been thanked: 264 times
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: Plus one
As this instruction effects ZF flag and it will be 1 if B_L overflows which causes the last line to read and ZF will be 0 if B_L doesn't overflow and last line will be skipped. This three line is certainly enough for UInt; I don't find any reason of using first two-lines.INCF gbl_FCV_B, F
