I'm experimenting the servo macros on my custom board based on PIC18F87k22.
I'm trying to drive a hobby servo on port RF7, but nothing moves.
I tried to drive this pin manually and I can make this servo move, though I'm asking myself if there is some restrictions for using the servo macro commands (must it be a capture compare pin or something)?
You can see in my attachement 2 files:
- servo.fcf does not work and uses servo macro commands
- servo_test.fcf is just toggling an output pin at the desired chronogramm to make the servo move between 2 positions.
If you have any idea that could explain why the servo macro commands cannot be used, I'll be happy to check tem.
Thank you,
Servo on PIC18F87k22
etillol
- Has thanked: 2 times
- Been thanked: 3 times
- servo_test.fcf
- (4.5 KiB) Downloaded 351 times
- servo.fcf
- (5 KiB) Downloaded 339 times
- Dan81
- Been thanked: 60 times
Re: Servo on PIC18F87k22
Hello Etillol
I think there is a little bug in Flowcode.
If you put only 1 channel , it doesn't work.
Put 2 channels and it should be OK.
Daniel
Daniel
etillol
Thank you for the tip but it doesn't work yet.
I took a look on the C code and it seems that the servo macros are based on interrupts on ccp1 (or ccp2) peripherals.
But I was wondering if it could use ccp peripheral to generate timings without using corresponding pins?
As I don't use this pins, it may explain why I don't have any pulse on RF7 pin.
What do you think of that?
I also suspect some config bits that could interfere with CCP peripherals, but it's just an intuition.
void MX_INTERRUPT_MACRO(void)
#ifndef MX_MIAC_SYSTEM
if (ts_bit(pir1, CCP1IF) && ts_bit(pie1, CCP1IE))
if (MX_SERVO_IDX < MX_SERVO_NO_CHAN)
FCD_Servo0_TogglePort(MX_SERVO_PORT_ARRAY[MX_SERVO_IDX], MX_SERVO_PIN_ARRAY[MX_SERVO_IDX], 1); //Start Servo duty cycle
MX_SERVO_CALC = MX_SERVO_TRIM[MX_SERVO_IDX] + MX_SERVO_POSITION[MX_SERVO_IDX]; //Calculate the required position
MX_SERVO_CALC = MX_SERVO_CALC * MX_SERVO_CLK_COUNT; //Calculate the number of clock cycles required
MX_SERVO_CALC = (MX_SERVO_CALC >> 8) & 0xFFFF; //Shift back to be 16-bit
ccpr2h = ( MX_SERVO_CALC >> 8 ); //Setup capture compare registers
ccpr2l = ( MX_SERVO_CALC & 0xFF );
cr_bit(pir1, CCP1IF); //Clear interrupt
if (ts_bit(pir2, CCP2IF) && ts_bit(pie2, CCP2IE))
if (MX_SERVO_IDX < MX_SERVO_NO_CHAN) //If channel is active
FCD_Servo0_TogglePort(MX_SERVO_PORT_ARRAY[MX_SERVO_IDX], MX_SERVO_PIN_ARRAY[MX_SERVO_IDX],0); //End of control pulse
MX_SERVO_IDX = (MX_SERVO_IDX + 1) & 0x07; //Increment channel
if (MX_SERVO_REQUIRED[MX_SERVO_IDX] > MX_SERVO_POSITION[MX_SERVO_IDX])
MX_SERVO_POSITION[MX_SERVO_IDX] = MX_SERVO_POSITION[MX_SERVO_IDX] + 1; //Increment duty
if (MX_SERVO_REQUIRED[MX_SERVO_IDX] < MX_SERVO_POSITION[MX_SERVO_IDX])
MX_SERVO_POSITION[MX_SERVO_IDX] = MX_SERVO_POSITION[MX_SERVO_IDX] - 1; //Decrement duty
cr_bit(pir2, CCP2IF); //Clear interrupt
#endif
