Semiconductor Temperature Sensors
Posted: Sun Jun 16, 2013 5:06 pm
by JohnCrow
I have, over the last couple of years experimented with several different types of solid stare temperature sensor devices.
These mostly have a direct mV/°C output.
The biggest problem with most of them is they don't measure negative temperatures, exceptions to this are normally more complex to use.
The DS18S20 can read negative but uses the 1 wire bus. While supported in FC it is not as easy to use as the above type.
The LM335Z can read negative but its output is mV/K (Kelvin).
This needs an extra line of calculation to convert back to °C, and the hardware needs a trimmer and pull up resistor to set the optimum accuracy.
The TMP102 has a good accuracy but uses the I2C bus. This can make programming tricky for the inexperienced
I've recently tried the TMP36 device.
This again has a 10mV/°C but reads from -40° to +125°C (Data sheet figures).
It can run with a supply of 2.7 V to 5.5 V and has a worst case accuracy of 2°C (1°C around 25°C), which make using it with ARM devices as simple as PICs and AVRs.
No extra hardware is needed, just a simple 3 wire connection.
Pin1 = Vcc
Pin2 = Out
Pin3 = Gnd
The device is ideal as the basis of a wide range thermometer.
Ive attached a simple example flowchart below.
TMP36_Sensor_Test.fcf
Test Flowchart
(10.5 KiB) Downloaded 637 times
Re: Semiconductor Temperature Sensors
Posted: Sun Jun 16, 2013 5:34 pm
by Steve001
[quote="JohnCrow"]I have, over the last couple of years experimented with several different types of solid stare temperature sensor devices.
Hi john i know that you like playing with temperature sensors have you seen the devices on analouge devices site ? if you create a id they can send you FOC samples :D i have obtained a few devices this way .
http://www.analog.com/en/analog-to-digi ... re_Sensors
above is the selector
spark fun do a SOT23 to DIP convertor pcb
http://proto-pic.co.uk/sot23-to-dip-ada ... tAodgwsAmA
registration page
https://registration.analog.com/Registr ... ?locale=en
Posted: Sun Jun 16, 2013 5:38 pm
by JohnCrow
Hi Steve
Thanks for the links, I keep intending to try and get a few samples from various places.
Ive used the sparkfun breakout boards for SMD to dip, they are useful devices.(Not tried that one though)
Posted: Sun Jun 16, 2013 6:37 pm
by Steve001
there is this little beauty just had to go and dig it out of my components box a tad expensive i know
not had chance to play with it yet tho :(
http://uk.farnell.com/jsp/displayProduc ... tch|p|plid|
it interfaces various thermocouples to a 10mv/c signal this one is type K (−200 °C to +1350 °C)
steve
Posted: Sun Jun 16, 2013 7:22 pm
by JohnCrow
Hmm
I used them (or maybe a similar device) for a project when I was at college (paid for by work so cost didnt matter).
They worked very well.
Just used a DVM module to show the temperatures.
Posted: Mon Jun 17, 2013 7:56 am
by jgu1
Hi John/all! :D
I also made a program with a TPM36. I would use it for a thermostat.
You can adjust its nominal temperature by pressing Set then the up / down. If you press Set again, you can adjust the hysteresis of temperature upwards. press again Seen and you can adjust the hysteresis down. Press Set again and the thermostat will turn on and off the set formulas. The accuracy is only in whole degrees. The program stores the adjustments in EEPROM, so a power failure retrieves the data again. There is certainly something that can be improved, but it works fine by me. Maybe useful :idea:
Best regard
Jorgen
Posted: Mon Jun 17, 2013 9:45 am
by Kenrix2
Some Pic micros have a temperature unit. I have used them in the past for various monitoring uses but not for getting the the exact degree centigrade.
Here is a sample. It is made with V4.5 ,however, it should work with V5.
Posted: Mon Jun 17, 2013 6:44 pm
by JohnCrow
Hi Kenrix
Thats a very interesting idea, just tried it with the 16F1827 and FC5
It seems to work as you say. Gave the PIC a spray with an inverted air duster, and cooled it down and the display shows about 160.
Room temp is about 24°C and its showing 210.
As you say not highly accurate, but it could certainly be useful.
Thanks for the info.
Posted: Mon Jun 17, 2013 6:56 pm
Here is my two pence worth.
How about this:
http://uk.farnell.com/jsp/search/produc ... ku=1439483
 THERMISTOR, LINEAR 19.53MV/C, TO-92
 IC Output Type: Voltage
 Sensing Accuracy Range: ± 2°C
 Sensing Temperature Min: -40°C
 Sensing Temperature Max: +125°C
 Supply Voltage Min: 3.1V
 Supply Voltage Max: 5.5V
 Sensor Case Style: TO-92
 No. of Pins: 3
 Resolution (Bits): 8bit
 Supply Current: 6µA
 SVHC: No SVHC (19-Dec-2012)
 Base Number: 9701
 Operating Temperature Max: 125°C
 Operating Temperature Min: -40°C
 Operating Temperature Range: -40°C to +125°C
 Output Current: 100µA
 Output Voltage: 400mV
 Output Voltage per °C: 19.5mV/°C
 Package / Case: TO-92
 Resolution: 8bit
 Sensor / Transducer Type: Temperature
 Supply Voltage Range: 3.1V to 5.5V
 Temperature Sensing Range: -40°C to +125°C
 Termination Type: Through Hole
Price from Farnell:
Qty	   List Price
1 - 9	  £0.24
10 - 99	£0.159
100+ 	  £0.133
Since Output Voltage per °C: 19.5mV/°C ( 5/256=19.53mV)
That makes flowcharts very easy to create.
So bytes increase/decrease by 1 every deg C
Also no additional components are required.
