Would it be possible and how to implement the possibility to create new components, or functions directly from C code, and them have them as standard library, like for the example I did with the inverse sqrt() function? Instead of having them as macros? Or is this just a no brain'er?
Cheers,
Mantas
Re: Function-component creation from C code
Posted: Wed Aug 28, 2013 12:23 pm
Hi Mantas,
The Embedded Macro and Hidden Embedded Macro options in the Interface manager are basically for this very purpose and allows us to build components which either call existing C functions without any additional overhead or to call code e.g. to read or write to an array as used in the DSP components.
Posted: Wed Aug 28, 2013 1:24 pm
by Mantas
Hi Benj,
Sorry for the stupid question, but where do I find this Interface manager?
More info can be found in the Wiki but I have some writing on this section still to do so I could try and add to this extra info in later today.
Posted: Wed Aug 28, 2013 5:11 pm
by JonnyW
Hi. Dave has produced a video on the interface manager here:
[/youtube]
Jonny
Posted: Sat Aug 31, 2013 7:28 am
by Mantas
Hi Gents,
Could you create a video of showing how to create a component, or a function specifically from C code? I know there is a supplementary section in the settings manager an others, but this is still mind boggling for me What if a C code function to call has a pointer in the parameter section...you know some more complicated functions implementation done by you in a video would be very interested to see.
Thanks in advance! You are doing an amazing job there!
Best regards,
Mantas
Posted: Mon Sep 02, 2013 8:46 am
by JonnyW
Hi Mantas. Yes, it would certainly be possible to do a video on this.
As far as pointers go, we get around that when using DLLs by using an array of 1 element, but all macros must conform to Flowcodes procedure-call standard, that is that every array is followed by its size, and the return type (if a string) is the final argument. This is easily fixed with a #define though:
I've wanted to do a video on embedded component macros for a bit, so see if there is time today now I know there is demand.
Cheers,
Jonny
Posted: Mon Sep 02, 2013 12:58 pm
by Mantas
Hi Jonny,
I would really appreciate that! This would simplify a big part of my work were I need to convert C code to flowcode!
Cheers,
Mantas
Posted: Mon Sep 02, 2013 1:32 pm
by JonnyW
Because we moved buildings the audio equipment is tucked away somewhere, but I have scripted a video and hopefully can roll that out when the box with the microphone us uncovered.
