Configuration of PIC24FxxKA302 not possible
Posted: Thu Aug 29, 2013 7:25 pm
by Nigel_K
For a project I wanted to use a PIC24F32KA302 controller that can be chosen when creating a new project in Flowcode. When I want to configure the chip (=>project options>configure) a message box appears that's saying "unrecognized chip". Furthermore in the drop-down menu of the configure window there's no PIC24F32KA302. Same for PIC24F16KA302. I don't know whether this is also the same for other targets. Actually this is very bad for me because those controllers are the best (Flowcode-supported) choice for the projects I have on my schedule...
Could you please help to solve this issue?! I'd be glad to get a statement soon. :)
Re: Configuration of PIC24FxxKA302 not possible
Posted: Thu Aug 29, 2013 9:44 pm
by kersing
Drop the two files included in the attached ZIP in the Tools\PPP folder of you installation (C:\Program Files (x86)\Flowcode(dsPIC)\v5\Tools\PPP) and you should be able to configure the PIC24F32KA302. I can add the PIC24F16KA302 as well if required.
Posted: Sat Aug 31, 2013 3:31 pm
by Nigel_K
Thank you so much (again)!! :D
With those files I can configure the chip in Flowcode now. Whether it works on the target I can't figure out yet - I'll order the chips today!
By the way: Yes, a same support for the PIC24F16KA302 would be great too. ;)
P.S.: Is there any "DIY" for modifying those "PPP"-files or is it "closed" knowledge for MatrixMultimedia & Valued Contributors?! I couldn't find a fitting entry in the forum...
Posted: Sat Aug 31, 2013 6:39 pm
by kersing
The files are basically a translation of the configuration information in the Microchip data sheets into parameters for PPP. I am not aware of any information on the subject on the forums, haven't gotten any from MM either, just studied the files (some time ago).
I will try to add the other devices later in a few days.
Posted: Sat Aug 31, 2013 8:32 pm
by Nigel_K
Ah ok, it's more "getting into it" then.
I'm not that familiar with the "Flowcode-background" yet...
BUT I figured out today, that my project needs more an up- than a downgrade concerning the controller. :shock:
So I have probably to switch to the "PIC24F32KA304" with which it is the same ("no configure out of the box..."). So if you would add another PPP (in terms of my "needs"), I'd rather ask you for the PIC24F32KA304 now. - Sorry for this turn. :oops:
Posted: Sat Aug 31, 2013 10:01 pm
by kersing
No problem. The 304 should have been there as MM included it, somehow I managed to remove it, so my bad.
Attached a new archive with the two files, 24F32KA304 is there, so are the 24F16KA302 and 24F32KA302. (I tried to configure all three to make sure.)
I haven't been able to test them as I don't have these devices available, feel free to contact me if there are any issues.
Posted: Sun Sep 01, 2013 1:25 am
by Nigel_K
Yes, it seems to work now! :D
Thanks again for your fast support - and for sure I'll let you know (here) if there should be an issue related to the configuration on the real target. ;)
