EBM001-GLCD Mirror Immage
Chris_MIRA
Has thanked: 2 times
Been thanked: 21 times
Post by Chris_MIRA »
Hi, Im using a EBM001 and flowcode v6, the display works fine in simulation but when I put the code into hardware (using a PIC 16F877A on the EB 006 board) pluging into port B, the text is mirror imaged and in the wrong orrientation (by comparison with the simulation). I cant find anything either is software or hardware that would give this effect. Help anyone?
Chris
Chris_MIRA
Re: EBM001-GLCD Mirror Immage
Just an update, module works fine when using Flowcode 5 so looks like a V6 issue?
Hi Chris,
I have found the issue and it is now resolved. The file below should fix the issue if copied into your "Flowcode v6/Components" folder before starting Flowcode.
gLCD_EBM001.fcpx
(54.79 KiB) Downloaded 353 times
This fix will be included in the next update release.
