Dear,
The file in attachment work in the simulation and the file does not work in the Miac module.
What is it wrong?
Best regards
Nazaire Verrue
Miac module
Nazaire VERRUE
- Been thanked: 3 times
Re: Miac module
Hi Nazaire,
I have tried your Flowchart on my Miac, and when I2 is high, output A goes high with LED lighting up.
So your flowchart is correctly working.
I have attached an alternative flowchart (not saying your flowchart is wrong since it's working),to show there is more then one way of controlling Miacs.
Also as a Miac test to see if your Miac is being programmed correctly , output D will be toggling every second as soon as power is connected
- Oefening1b.fcfx
- (9.48 KiB) Downloaded 393 times
Nazaire VERRUE
Re: Miac module
Hi Martin
The sw_toggle_mtl_pcb1 is connected with I1. I1 does not work but I2 work well.
What is it wrong?
Best regards
Nazaire
What is it wrong?
Best regards
Nazaire
Re: Miac module
Hi Nazaire
Just Change from I2 (RA1) to I1 (RA0).
You will need to take notice of functions that's not within brackets.
It's connected to I2 not I1: Since originally you did not state which input your connected to, I would not have known you wanted it to work with I1 instead of I2.Nazaire VERRUE wrote:The sw_toggle_mtl_pcb1 is connected with I1
Nazaire VERRUE
Re: Miac module
Hi Martin
In the properties can i not sw_toggle_mtl_pcb1 connected with port A = 0 (RA0) there is alone port A = 1 or 2 or 3 or 4.
Wat is it wrong in tis properties of sw_toggle_mtl_pcb1?
Best regards
Nazaire
Best regards
Nazaire
Re: Miac module
Not having problem with selecting I1 (A0):
If your having problems selecting I1, then are you running the latest version of V6 (6.0.2.0 (27.09.2013))
If not take a look at this:
http://www.matrixmultimedia.com/mmforum ... 54&t=12949
Perhaps you can post some screen shots to show what the issue is.
Attached is a Flowchart that is using input I1
- Oefening1c.fcfx
- (6.37 KiB) Downloaded 378 times
Nazaire VERRUE
Re: Miac module
Hi Martin
I am running now the latest version of V6 (6.0.2.0 (27.09.2013)).
Now it work correct.
Thanks Martin for the help.
Best regards
Nazaire
Best regards
Nazaire
