Bug with 18F67J60 ( no configuration words in hex file )
Posted: Mon Oct 21, 2013 4:28 pm
by Mathy
I'm trying to program a 18F67J60 MCU but when I tried to import the hex file into the pickit 2 software I have a warning message :
No configuration words in the hex file.
Do you know why ?
I don't have any problem with other 18F MCU. Only with this one.
Thank you for your help
Re: Bug with 18F67J60 ( no configuration words in hex file )
Posted: Mon Oct 21, 2013 4:33 pm
Hi Mathy,
Can you post your v5 program and I will have a look for you.
Posted: Mon Oct 21, 2013 7:30 pm
by Kenrix2
You will always get that warning if you do not open "Configure chip..." and click "OK". It doesn't matter what micro you are using. It's nice that it works that way.
Edit: Your right, I just tried it on the PICkit2 with that chip selected and the configuration is always FFFF FFFF FFFF FFFF.
Posted: Mon Oct 21, 2013 9:41 pm
by Kenrix2
Could you please try the following to see if it works.
In the file 18F67J60.fcd located in the FCD folder,
Change ConfigAddress=0x300000 to ConfigAddress=0x1fff8
Posted: Mon Nov 04, 2013 2:57 pm
by Mathy
Thank you for the tips.
I will try this as soon as I can and let you know.
Thanks again,
Mathy
Posted: Sat Dec 07, 2013 11:40 am
by cubitus54
I have the same problem.
The solution works well.
thank you
