Arduino/C Library Integration
Posted: Mon Oct 21, 2013 10:20 pm
by manuel_bayer
is it possible to integrate my arduino libraries into my arduino flowcode project or to create a component out of my arduino library?
I want to integrate the ds1307 library into flowcode for example, if yes, can someone explain me how to do that?
I read this article http://matrixmultimedia.com/blog/?p=146, but i dont know how to turn complex libraries into my project.
I would be happy to get some help.
Re: Arduino/C Library Integration
Posted: Tue Oct 22, 2013 5:27 pm
Do you know what format the Arduino libraries are in as I've never really used their software?
If they are in native C then shouldn't be an issue. If they are precompiled then might be more tricky but still probably do-able by editing the link script.
Either way yes you should be able to create components to wrap around the existing libraries. Only issue will be that the components will only work for AVR or maybe only Arduino based targets.
Posted: Tue Oct 22, 2013 10:14 pm
by JonnyW
Hi.
There is a blog post here: http://matrixmultimedia.com/blog/?p=146
This details how to get an existing C routine 9or library call) defined in a Flowcode component. This wouldprobably be the start of this,if you have a header file with the routines you want in it.
Jonny
