Looking for a 433Mhz (EB063) TX-RX example
MJU
Has thanked: 121 times
Been thanked: 108 times
Post by MJU »
I’ve made two simple 433Mhz (EB063 on port C) flowcharts.
Both programmers are Multiprogrammers with a 16F877A.
I’ve looked into the RF macro’s and made these flowcharts in a way I think they should work.
The TX looks like it sends a byte every second, the RX receives something according to the acknowledge. But when I read the acknowledge it returns 254.
This means (according to the help file in V5) that it receives only the length of the data.
“A return value of 254 indicates that the length byte was received but no data.”
Can anyone look into these flowcharts and tell me what I’m doing wrong?
I just have to know the right order for the macro’s to read and send data for these e-blocks.
I have put the programmers a few meters from each other to make sure they don’t disturb each other with a to strong signal.
Any suggestion is welcome..
TX V6.fcfx
This is the sender.
(9.26 KiB) Downloaded 306 times
RX V6.fcfx
This the receiver
(9.99 KiB) Downloaded 270 times
acestu
Has thanked: 783 times
Been thanked: 223 times
Re: Looking for a 433Mhz (EB063) TX-RX example
Post by acestu »
Hi MJU,
You might find this old post of mine interesting, it uses a 433 mhz tranceiver ....
http://www.matrixmultimedia.com/mmforum ... 46&t=11583
cheers
Acestu
MJU
Post by MJU »
I've read that post, but it tells me nothing about the EB063 Eblock and why my code doesn't work.
Thanks anyway
MJU
Post by MJU »
In this thread: http://www.matrixmultimedia.com/mmforum ... 063#p47368 I found a Flowchart that works.
My problem seems to be in the Timeouts for the receive macro...
How do I set a timeout that works?
I send every second a byte to the receiver and show it on the LCD.
Does the time out has to be longer or shorter than the frequency the sender sends its bytes?
