Bug in RS232 Makro
Posted: Sun Oct 27, 2013 7:00 pm
by HjH
In the " FCD_02e3_RS232__Initialise();" is a bug.
All settings in the RS232 properties are not effectively.
You can the Makro "RS232 Initialise" replace with my Makro "Init_RS232_33FJ128GP802"
Microcontroller: 33FJ128GP802
Init_RS232_33FJ128GP802.fcm
(2.48 KiB) Downloaded 405 times
HjH
Re: Bug in RS232 Makro
Posted: Mon Oct 28, 2013 4:22 pm
Hello HJH.
Do you know which settings are not being setup correctly using the standard Initialise macro? Also which version are you using? 6.0.3 is the latest release and contains the latest set of fixes.
I have also just done a lot of work at getting the devices/components with remappable I/O to work correctly and expose the remapping via the component properties. All working very nicely now and should be complete for 6.0.4 which will be released shortly.
