LED Matrix Module
Posted: Fri Dec 27, 2013 11:14 am
by JohnCrow
8 x 8 LED Array
Introduction:
This project describes the building and testing of a simple 8 x 8 LED Array Module.
The unit is about 35mm x 35mm and contains 8 rows of 8 LED’s.
Unlike the Matrix E-Block this has dual colour LED’s (Red & Green), but is not able to be multiplexed.
The device is common anode and has a total of 24 pins.
The datasheet is not at first glance overly clear on the connections, but once studied for a few minutes all will be clear.
(Helps if you can read Chinese too  )
Hardware:
1 x Oolout LED Array (Costs about £3.00)
2 x 8 Pin SIL Header Sockets
2 x 8 Pin SIL Header Pins
1 x Piece Of Vero-Board to suit
1 x EB 006 Microcontroller Programmer.
3 x 9-PIN D To SIL Header adaptors
Female – Female Jumpers.
Connections:
The device was soldered to a piece of Vero-Board using SIL sockets to allow the module to be removed easily.
Sill Headers are used to allow jumper cables to connect the module to the microcontroller programmer or an Arduino.
The main disadvantage using these sort of connections is a total of 24 data lines (Ports B, C, & D) are needed.
The vertical pin spacing is very slightly different to standard proto-boards / vero-boards etc. To get round this it is possible to bend the pins inward slightly. Horizontal spacing is fine.
Anodes are connected to PORT C on the Microcontroller
  • PIC LED
    0 11
    1 19
    2 16
    3 13
    4 3
    5 6
    6 9
    7 12
Cathodes are connected to PORT B = RED and PORT D GREEN. These are all connected via a 1k-ohm resistor.
Two resistors were used rather than just one on the anode, so both LED’s can be turned on at the same time. (Giving an orange colour). Just using 1 resistor, would allow double the current to flow in each colour if used like this.
PORT D
  • PIC LED
    0 24
    1 21
    2 18
    3 15
    4 1
    5 4
    6 7
    7 10
PORT B
  • PIC LED
    0 23
    1 20
    2 17
    3 14
    4 2
    5 5
    6 8
    7 11
Test Programs:
Some simple test programs were written to verify operation of the module.
Simple Binary Counter
Each row is turned on in sequence, counting from 0 to 255 in binary. (All columns lit) The same program was tried with each column being lit in sequence, again counting from 0 to 255 in binary (All rows lit)
These were repeated using both green and red led’s. A third test was done using both on together.
A set of sample flowcharts for both FC5 and FC6 are attached below.
Using a shift register such as a 74HC595 will allow the device to be driven with less data lines.
Video Link:
A simple video captured with my Smartphone showing the operation.
http://youtu.be/Iah2zRzs_8M
Matrix Demos.zip
(10.7 KiB) Downloaded 901 times
Re: LED Matrix Module
Posted: Thu Jan 09, 2014 6:40 pm
by acestu
Hi John,
I got one of these Matrix displays in an Arduino kit, however there dosen't seem to be any markings on the pins, it has 2 x lots of 8 pins like yours, is there an orientation mark on them somewhere or a pin 1 mark etc ?
cheers
Stuart
Posted: Thu Jan 09, 2014 7:20 pm
by Steve001
Hi stu,
i have one of these somewhere
http://www.farnell.com/datasheets/1698877.pdf
you could compare with a meter on diode check to see what's what
Posted: Thu Jan 09, 2014 8:14 pm
by JohnCrow
There is a pin 1 marking, though you need a mag lens to see it.
Mine has 2 lots of 12 pins (dual colour)
With pin 1 top right, pin 12 is top left
pin 13 is bottom left and pin 24 bottom right.
It does have a " HX" printed on the top edge when orientated as above.
http://oomlout.co.uk/collections/extra- ... 8-bicolour
Posted: Thu Jan 09, 2014 9:27 pm
by acestu
Hi John,
I will get my magnifying glass out and have a look then, also thanks for the link I have just ordered one to have a play with..... :D
cheers
Stuart
Posted: Thu Jan 09, 2014 10:52 pm
by JohnCrow
Hi Stu
They are a nice little unit, especially for the cost.
I ordered a few shift registers as well with mine as well. With that I'll be able to use a lot less pins on the PIC to drive them.
Taking 3 ports is certainly a bit over the top.
Though testing Jordys component and the Vinculum module is top of the list for this weekends projects :)
Posted: Fri Jan 10, 2014 7:00 pm
by acestu
Hi John,
Which shift registers did you get ?
cheers
Stuart
Posted: Fri Jan 10, 2014 7:56 pm
by JohnCrow
the Shift registers are 74HC595. I ordered them same time as the LED Matrix
Posted: Fri Jan 10, 2014 11:07 pm
by acestu
Thanks John, I will order some..............
Stuart
Posted: Sun Jan 12, 2014 6:38 pm
by acestu
Hi John,
The FC6 demo files will not open, one says Attribute "Start" Not found, another says Attribute "count" Not found...do you have any ideas please...
cheers
Stuart
Posted: Sun Jan 12, 2014 9:44 pm
by dazz
HI Stu
It's probably because John using a pre upgrade version(testing version of the upcoming patch) of v6, try importing the V5 version
Dazz
Posted: Sun Jan 12, 2014 9:47 pm
by acestu
Hi Dazz,
I have just told John in a PM that this is the same problem that you and I had the other day.....
cheers
Stu
Posted: Sun Feb 02, 2014 9:24 pm
by acestu
Hi John,
I have just picked a few of these up with built in shift register, not sure how to use them though....
(321.92 KiB) Downloaded 15212 times
cheers
Stuart
Posted: Sun Feb 02, 2014 10:32 pm
by JohnCrow
Hi Stuart
Looking at the photo without the data sheet
My thoughts are
1 The number on the DIN (Data In?) line that sets the LEDS on
2 Suspect the CS line selects the Vertical row (same as point 1) using binary
3 Then pull CLK high or low to send the data
Where did you find them?
Posted: Sun Feb 02, 2014 10:37 pm
by acestu
Hi John,
I am trying to get a datasheet for them, all I know is that the chip on the board is a MAX7219 which I beleive is an LED driver chip, I will see what happens this week because the Chinese are on national holidays....
cheers
Stuart
P.S. They are on EBAY here: http://www.ebay.co.uk/itm/300975480543? ... 1439.l2649
Posted: Sun Feb 02, 2014 10:47 pm
Hi Stuart
While you waiting for the datasheet on the product, you can get an idea from the datasheet of the MAX721 driver:
http://datasheets.maximintegrated.com/e ... AX7221.pdf
Posted: Sun Feb 02, 2014 11:20 pm
by acestu
Thanks, I have the datasheet for the Max7219, I am waiting to see if I can get a datasheet for the actual board because it has some more components underneath the matrix and it may have some examples with it...
cheers
Stuart
Posted: Tue Feb 04, 2014 12:06 am
by Spanish_dude
The MAX7219 has a 16 bit register which is used to set or clear the LEDs.
You write in that register by setting or clearing your DIN and then having a rising edge on the CLK pin. CS has to be low.
Each time there's a rising edge, the register will be shifted right.
There's some configuration at start-up you have to do.
At start-up, the IC is in shutdown mode. You have to leave it in this mode and configure it before changing it to normal mode.
The MAX7219 has a built in BCD to 7 segment decoder, which has to be disabled (I think it's enabled at start-up).
To disable the decoder you want to send the following value: 0x09 << 8 | 0x00 (See p.7).
You can also set the brightness of the LEDs by sending : 0x0A << 8 | brightness_low_nibble (See p. 9).
The brightness is set by using the lower nibble of a byte.
One last thing before setting it to normal mode is telling the IC how many displays you have, or in this case, how many rows/columns.
Because it's an 8x8 LED matrix you can send this value : 0x0B << 8 | 0x07 (See p. 9).
Now, to set it to normal mode you have to send the following value: 0x0C << 8 | 0x01 (See p.7).
You should be able to send the data for the LEDs now. That's done by sending : row << 8 | column (See p. 7).
The row starts from 1 to 8 and the column is an 8 bit value which sets or clears the LEDs.
- Nicolas
PS: The MAX7219 has a DOUT, but I don't see it on your PCB. That's a shame, you could have simply cascaded the LED matrixes to make one big/long LED matrix.
Posted: Tue Feb 04, 2014 8:18 pm
by acestu
Hi Nicolas,
Thanks for the info, the board does have a DOUT as per pic, I want to connect 4 or 5 togethor side by side and make a scrolling sign....
(195.85 KiB) Downloaded 9037 times
cheers
Acestu
P.S. That is not a crisp under my control key
Posted: Tue Feb 04, 2014 9:09 pm
by Spanish_dude
Didn't see those pins underneath the LED matrix, nice :D.
- Nicolas
Posted: Sat Feb 08, 2014 10:28 pm
by STibor
Here is one example of display.
http://www.matrixmultimedia.com/mmforum ... rix#p56874
I attach an example of four display.
Do you have any ideas for scrolling your characters?
