Problem with panel properties
Posted: Mon Jan 20, 2014 2:15 am
by pantelisthrylos7
I have a problem in viewing the panel properties. It is not possible to edit any component properties in dashboard or system panel.
New patch run succesfully. All other items in view menu are visible.
Can anybody give an idea what might be?
Re: Problem with panel properties
Posted: Mon Jan 20, 2014 10:50 am
The window might be docked somewhere. If you go into the View menu then maybe try disabling and re-enabling the window and see if you can see anything change on screen which might indicate where the window is docked.
I think there is a way of resetting all the windows so I will find out for you.
Posted: Mon Jan 20, 2014 12:30 pm
by pantelisthrylos7
Hello Benj,
I have done this already just before my post. Nothing seems to change on the screen. It will be very helpful if I could reset the windows view.
Thanks In advance mate,
Pantelis
Posted: Mon Jan 20, 2014 12:45 pm
by JonnyW
Hi.
if you delete the registry key:
CURRENT_USER\Software\MatrixMM\FlowCodeV6\Workspace
This should reset your window layouts.
Cheers,
Jonny
Posted: Mon Jan 20, 2014 2:05 pm
by pantelisthrylos7
Ok I did it and it's true the windows reseted.
Now I can see the property window again.
Thanks very much Johnny and Ben.
