I use timer2 and timer4. I get silly result using timer2 and timer4.
To find out what happens I disabled (did not enabled) timer 2 by means of goto label A in macro "Send_Bits". Nevertheless the timer2 interrupt macro "Timer2_Interrupt" is called by the program. This can easily be shown because this interrupt macro is the only one which can change the output state of B0. And I see B0 changing with 77.5 Khz.
How can help me?
Kind regards
Jan Lichtenbelt
PS. In the meanwhile I produced the same program also in Flowcode5. That one works as it should be / as expected.
Timer2 call with Timer2 disabled
- Jan Lichtenbelt
- Has thanked: 128 times
- Been thanked: 264 times
- DCF_transmitter_F5_V1.fcf
- Flowcode 5
- (22.17 KiB) Downloaded 219 times
- DCF_transmitter_V1.fcfx
- Flowcode 6
- (22.44 KiB) Downloaded 192 times
Re: Timer2 call with Timer2 disabled
Hi Jan,
Think I have spotted the problem. The timer 4 interrupt is calling the timer 2 macro. Just noticed it by comparing the C code produced by v5 and v6.
- Jan Lichtenbelt
If one looks to long to a problem, one will miss the details.
Thanks a lot for helping. Indeed the wrong interrupt macro has been used for timer4.
Kind regards
Jan
Kind regards
Jan
