I2C with 16F1847 error This chip does not have Master I2C
Posted: Sat Jan 25, 2014 8:53 am
I would like to use the I2C bus on a 16F1847.
At the Compiling A I have this error message:
Normal?
Same error on Flowcode V6.04
thank you
Starting preprocessor: C:\PROGRA~2\Flowcode\v5\Tools\boostc\pp.exe "test_pression GY65.c" -i C:\PROGRA~2\Flowcode\v5\Tools\boostc\include -d _PIC16F1847 -la -c2 -o "test_pression GY65.pp" -v -d _BOOSTC -d _PIC16 -d _PIC16x -d _CHAR_INDEX
C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_I2C.c(319): This chip does not have Master I2C capability
1 errors detected
thank you
PIC16(L)F1847
The I2C interface supports the following modes and
features:
• Master mode
• Slave mode
• Byte NACKing (Slave mode)
• Limited Multi-master support
• 7-bit and 10-bit addressing
• Start and Stop interrupts
• Interrupt masking
• Clock stretching
• Bus collision detection
• General call address matching
• Address masking
• Address Hold and Data Hold modes
• Selectable SDAx hold times
