Why is it impossible to load that program in a 16F88
Posted: Mon Aug 25, 2014 3:05 pm
by DELAK_ALED
Why is it impossible to load the progam (see attachement) in a 16F88 microcontroller?
I receive the message: "Flash memory not verified - may be due to code protect"
I use a EB 006 00 8 program board in combination with flowcode V6.
Thanks in advance.
Re: Why is it impossible to load that program in a 16F88
Posted: Mon Aug 25, 2014 6:23 pm
by JohnCrow
I've just tried your flowchart on my EB006-V9 and EB006-V7 programmers, and it loads into a 16F88 ok.
I don't have a V8 board myself
Are you running the latest version of flowcode (FC 6.0.10) which also will have the latest version of mLoader.
There are a few posts referring to this problem on the forums, might be worth searching for those.
oef80nognietuitgetest.hex
(6.43 KiB) Downloaded 230 times
I've attached the hex file from your flowchart, you can try and load it directly with mLoader and hopefully that will get you going for now.
Posted: Tue Aug 26, 2014 10:34 am
by DELAK_ALED
I have sent the hex file with a pickit2 programmer to the chip, and now the programming goes fine.
So I think there is a problem with my EB006 board
Posted: Tue Aug 26, 2014 12:13 pm
by jgu1
Hi Delak!
I've had the same problem, unstable combiling to chip with different error messages. I downloaded the USB driver and installed it = "EB006 (v8 and older) USB Driver" from:
http://www.flowcode.co.uk/search_results ... chText=usb
Whether it directly have anything to do with it, I do not know, but seemed a better results when I combile from FC6 to EB006-8
And one more thing, don“t have anything connected to the port on EB board.
You can give it a try.
Best regard
Jorgen
