In fowcode4, I made a line followcer it works fine.
But when I make the same follower in FC6 on the same buggy, the buggy leaves repeatedly the black line.
How can I improve the FC6 program?
line follower in FC6
- Has thanked: 5 times
- Been thanked: 2 times
Re: line follower in FC6
I made now a line follower in FC6 without component macro's. It works verry well.
Is then the conclusion that the component macro's of the buggy don't work verry well in FC6 (and work verry well in FC4) a good conclusion? Or are there other reasons why the follower don't work with component macro's in FC6
- follower.fcfx
- (5.11 KiB) Downloaded 726 times
That's strange the component code in v4 and v6 should be pretty much the same.
Have you seen this Formula Flowcode line following example written in v6?
http://www.matrixtsl.com/wiki/index.php ... ec2007b406
