pic24ep128mc202
Posted: Wed Oct 15, 2014 10:04 am
by saschech@gmx.de
I have new install v6 and have the error at compiling.
The code run in Simulation well.
Pleas help
Regards Wolfgang
Re: pic24ep128mc202
Posted: Wed Oct 15, 2014 12:29 pm
Hi Wolfgang,
We are looking into the problem. Seems to only be effecting a very small percentage of our users. Are you using Avast anti virus by any chance?
Re: pic24ep128mc202
Posted: Wed Oct 15, 2014 12:48 pm
by saschech@gmx.de
hello Beny
yes,I use avast.
I deseable it bevor the new installing v6,because avast say the "fc_launcher.exe" is in the Quarantäne Folder.
but I put it bak...
The error , I have also if I deactivate avast.
Regards wolfgang
Re: pic24ep128mc202
Posted: Fri Oct 17, 2014 8:29 am
by saschech@gmx.de
Hello Benj
On my Workstation,I deinstall avast and zonealarm.
After a new install v6,I have the same error.
Regards wolfgang
Re: pic24ep128mc202
Posted: Sun Oct 26, 2014 8:23 am
by saschech@gmx.de
Hello Benj
Any News?
Regards Wolfgang
Re: pic24ep128mc202
Posted: Fri Oct 31, 2014 12:17 pm
by saschech@gmx.de
Hello Benj
I dont no the Situation,must I stop my proj. with these chip?
A other Problem with EXTI1 :
If jou test the c_code the value for pps-pin is set in bit0 to bit7 but it must set in bit8 to bit15.....
// Unterbrechung
// Unterbrechung: Aktiviere INT1
INTCON2bits.INT1EP = 0;
RPINR0 = (RPINR0 & 0xFF00) | 20; >>>>>> dont work on hardware
IEC1bits.INT1IE = 1;
// Unterbrechung
RPINR0 = ((RPINR0 & 0x00ff) | (20 << 8 )); >>>>> work on Hardware
Regards Wolfgang
Re: pic24ep128mc202
Posted: Mon Nov 03, 2014 10:17 am
by saschech@gmx.de
Hope for a answer
wolfgang
Re: pic24ep128mc202
Posted: Mon Nov 03, 2014 1:52 pm
Thanks for the spot, Just having a look through now to see if these devices need any other fixes.
Re: pic24ep128mc202
Posted: Mon Nov 03, 2014 2:14 pm
Hello Wolfgang,
Thanks for letting us know about the issue.
Right here are all the definition files that this bug effects. Hopefully it should now be fixed but let me know how you get on.
To apply the fix please extract the contents of the archive into your "C:\Program Files (x86)\Flowcode 6\FCD\PIC16" directory before restarting Flowcode.
PIC16 INT1 & INT2 FCDX Fix.zip
(269.37 KiB) Downloaded 291 times
Re: pic24ep128mc202
Posted: Tue Nov 04, 2014 8:38 am
by saschech@gmx.de
Hello Benj
Now it set the bits corect,but my Problem compile to hex ;the error exists still.
Regards Wolfgang
Re: pic24ep128mc202
Posted: Tue Nov 04, 2014 10:55 am
Hello Wolfgang,
Just tried a compile here using that device and it's working fine.
In Avast have you white listed the fc_licensing.exe file? Might also be worth checking the files Avast has blocked and seeing if any others are related to Flowcode.
If you disable Avast but do not white list the file then Avast will continue to block it.
Personally I used to love Avast but installing it recently on my server caused it to come to a crawl so it seems to have become very bloated and I certainly wouldn't recommend it to anyone any more. AVG had the exact same problem a few years back. NOD32 seems very good and stable but you have to pay for a license.
