Serial USB with FTDI 232 USB Chip
A forum where Flowcode v6 user created components can be shared, discussed and reviewed.
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
As I am working my way through FC I thought this might help some one else .
This project uses the FTDI Serial to USB chip to give an embedded controller USB functionality.I usually include the FTDI chip on my Proto type PCB which allow me real time data monitoring
of the controller .
Attached
(1) FC6 Project
(2) Visual Studio 2008 Project ,This project read the Raw ADC conversion data send over the Serial USB link and display the value,this project can be used with VB Express too the free version
Peter
Ps : I forgot to mention in my VB example I use a very simple timer event to initiate transmission by sending a send Command "S" and then read the serial Port as the mcu on this command transmit it data,
However you can implement the more appropriate way by creating a delegate routine that handle the data when it is received at the serial port A good reference is the Book from Jan Axelson " Serial Port Complete "
ISBN 978-1-931448-06-2
:D
Serial_USB_Basic.zip
VB.Net 2008 GUI
(69.29 KiB) Downloaded 456 times
USB Serial.zip
FC Project
(270.23 KiB) Downloaded 463 times
FTDI Chip Circuit Diagram
(18.6 KiB) Downloaded 3788 times
