V6 BackwardCompatible with V4
Manie Serrao
Flowcode V4 User
Has thanked: 10 times
Been thanked: 2 times
Post by Manie Serrao »
Morning All,
Is V6 fully Backward compatible with V4.... I was told it is not....??
Cheers
Manie
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: V6 BackwardCompatible with V4
Post by JohnCrow »
Hi Manie
As with all FC versions, the new version will read and run a flowchart from the previous version(s).
It may need minor tweaks to compile, but generally it should work out the box.
Once a V4 flowchart for example has been opened and resaved, compiled etc in V6 in wont open in V4 again so keep a backup copy if you want to use it in the older version again.
Flowcharts created in any version will not open in the previous version(s). This is normally true for most software.
Hope this explains everything
Manie Serrao
Flowcode V4 User
Thanks, That is what I expected.....Cheers
