Using TMR1 disables outputs B and C
Posted: Wed Jan 21, 2015 12:21 pm
I've come across a bit of a strange one, took me a while to pinpoint but I'm sure it is something I'm doing wrong.
Basically if I enable transistors B and C and then enable TMR1 both outputs are turned off. Is this a bug or is there a reason for it?
I've attached a file to show this. If you disable the top icon so that the timer is never enabled the outputs work fine. By enabling the timers the problem occurs. After flashing I always power cycle as until you power cycle the problem doesn't always show up. In the above code the macro timer1Test is empty.
Any help is greatly appreciated.
Ben
Ben
