I bought new PC with Windows 7 64 Bit.
I try to install FC 6.1.1 ( 22.01.2015 )
My FC Version is fall to HomeVersion
I take the same Userdata, Activation Key and Licenze Key like in WIN XP ( succesfull as Prof Version )
I have deaktivate
- G Data Firewall is off
- Windows Defender is off
- Windows Firewall is off
No Warning Message comes.
FC tell :
Your Key has been accepted....
Please close and restart Flowcode....
my Username is showing in Window "Show Licenzes"
but all packs are inaktive
after restart, same.
now, the problems are start from scratch again?
It is always very annoying and costly to come across the same old problems.
The dependence on the forum annoying if I'm honest.
Dear Matrix tsl!
A complete uninstall is no uninstall.
After re-installing my data is still displayed.
Why are not all RegKeys adjusted after uninstalling?
Why is it to register the product properly so complicated?
It always fails at the simplest things.
My Regkey and Data 're okay, even FC announces successful registration. But anyway Home version. No ChipPack active. And I can not compile a single project.
"You are not authorized. "
Thank you for this unhappy weekend now!
edit
Workaround:
After Install FC and register and shows HOMEVERSION without activated Chip Packs,
copy from succesfull registered FC version ( Professional ) the !important! basic.key ( install folder Flowcode \licenses ) from your "Windows XP" Install to the Windows 7 (x86) install folder.
Restart Flowcode and have phun.
Please MM!
Work at this crazzy Registry / "Armadillo Engine"
rudi
