is it a component issue
peterhalloway
Has thanked: 9 times
Been thanked: 5 times
Post by peterhalloway »
I am starting to play with e blocks again. I thought the simple program attached should just display the A/D input and therefore be a number between 0 and 255 on the glcd. However, when you increase the pot it gives the expected response but when you decrease it you get numbers above 255. I am not sure if it is a schoolboy error on my part or a problem with the glad component. Any help appreciated.
Pete
877test.fcfx
(12.51 KiB) Downloaded 192 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: is it a component issue
Post by kersing »
Are you clearing the area you are printing to get rid of the previously displayed information? If not the last digit of a 3 digit number might still be visible when then value has only two digits (or two digits if the new value has only 1 digit)
― C.S. Lewis
Hi Pete,
I agree with Jac whats causing the issue.
I have attached one way of clearing.
Here is another.
877test2.fcfx
(12.91 KiB) Downloaded 196 times
peterhalloway
thank you both. I knew it was likely to be me!
Pete
