RS232 works in sim but not real (Flowcode v6)
Posted: Sat May 02, 2015 8:28 am
Hello at all,
I am working since two days on the same problem. I want to send a combined string via RS232 SendString function with PIC 16 F 1937. The attached program first sends a constant string via that function. That works fine. When I then try to send a string which is produced via a Str=Str+Str2 the communication does not work... In the simulation everything works fine.
There is a gap between simulated values and real life I cannot explain. Any ideas?
