Editing *.fcpx component files
Posted: Thu Jun 18, 2015 2:19 pm
by outlawstc
Anyone have any good resources for this? What if i want to make my Spi component more capable at controlling the spi registers.
Re: Editing *.fcpx component files
Posted: Thu Jun 18, 2015 9:03 pm
by kersing
The component binaries cannot be modified. If you want to change a component you will need the source. Changing the SPI component would (probably) break all components using it or require updating them.
You could always look into creating your own component. Also the real low-level stuff for SPI is in XXX_CAL_SPI.c, plain C code you can modify. However this might break existing components, so keep an original copy around in case you break depending components.
Just curious, why are you not posting in the Flowcode 6 forum???
Posted: Fri Jun 19, 2015 11:42 pm
by outlawstc
Figured this would be a general question for flowcode not fully directed toward version 6
