PID temperature control
henryscott
Post by henryscott »
Dear,
I am looking about to use Flowcode 6 with PIC 18F45K20, to interface 2 NTC to control 2 Power resistors fot heating. And control all By a PID control. NTC are interfaced in the AN5 and AN6 input of the micro with a resistor shunt 10K to 5Vdc NTC data sheet is enclosded. and output are in the PORTD.0 and PORTD.1 with a triac to cut the power dimmering the power supply 230Vac for the Power resistors
Is there a block in Flowcode 6 about it?
Henry
tabella NTC.xls
(32.49 KiB) Downloaded 371 times
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: PID temperature control
Post by QMESAR »
I guess you can use the Control block PID found under DSP functions
(63.19 KiB) Downloaded 849 times
