Link 2 MIAC's via CAN Bus
Dave Squibb
Flowcode v5 User
Has thanked: 27 times
Been thanked: 22 times
Post by Dave Squibb »
Is any example code available showing how this is done?
I found this http://www.matrixtsl.com/mmforums/viewt ... =26&t=6734 but the link to
http://www.matrixmultimedia.com/MIAC-X.php is broken.
Thanks, Dave.
Re: Link 2 MIAC's via CAN Bus
Hi Dave,
Here is a v6 program we use for the CAN Bus Systems Locktronics Trainer.
This one program is programmed to all nodes and the EEPROM memory retail which node is which. On programming the MIAC select the Admin node. You can then monitor and send out CAN messages.
I can quickly make you a simpler example if needed but this should have everything you need.
Once you have to two MIACs communicating using CAN you can keep one with the CAN monitor running and program the second one to ensure what your doing is working as expected.
LK8902 - CAN Bus Systems 220615.fcfx
(180.75 KiB) Downloaded 515 times
