Pic16f1937 options error
Posted: Sat Feb 06, 2016 9:15 pm
by acestu
I thought I would have a go at the Ds18b20 1-wire in Flowcode 5 as I bought a standard lcd display, however when I select the pic16f1937 as the target, when I click on configure chip I get the following error:
(28.82 KiB) Downloaded 6550 times
Stuart
Re: Pic16f1937 options error
Posted: Sat Feb 06, 2016 9:28 pm
by acestu
I have just tried to download a new copy of PPP but the link on this page is a 404 error page:
viewtopic.php?f=8&t=77
I will have a look for another link
Stuart
Posted: Sat Feb 06, 2016 9:39 pm
by acestu
I found a valid link and installed the latest version but it does the same.
Stuart
Hi Stuart,
That error is more about the path of ppp rather than target device by the looks of it.
After all the message is stating cant find ppp executable file.
That is something has has to be sorted within compiler options.
For the path, as you have flowcode v6, Why do you either set the path for ppp within flowcode 6/tools
Or you can use mLoader instead of PPP as a programmer also within flowcode 6/tools directory
Posted: Sat Feb 06, 2016 9:50 pm
by acestu
This is how my path looks it seems to be right:
(49.68 KiB) Downloaded 6535 times
Stuart
Posted: Sat Feb 06, 2016 9:55 pm
acestu wrote: This is how my path looks it seems to be right:
Yes but that is path to Flwocode 6
The attachment in the original post shows flowcode 5
Have to tried to re-add path by using browse?
Posted: Sat Feb 06, 2016 9:59 pm
by acestu
Just noticed it is looking in programfiles instead of programfilesx86, need to change the path.
Stuart
Posted: Sat Feb 06, 2016 10:02 pm
by acestu
Sorry I have a terrible head cold and I have been messing with this all day :?
Stuart
Posted: Sat Feb 06, 2016 10:27 pm
by acestu
Ok
Sussed it Martin, although I am using PPP in Flowcode 5 the Path has got to be for Flowcode 6 as when I try to install a new copy of PPP in the Flowcode5 tools directory it asks me if I want to remove, modify or repair as there is already a copy of PPP in the Flowcode6 tools directory ie it will not let me install 2 instances of PPP, if I use the same Path for PPP in Flowcode 6 and Flowcode 5 it works....
(55.46 KiB) Downloaded 6509 times
Stuart
