hi
if we can do by select the saved user compiler options on toolbar would be fine,
if we have two , each for compiler settings and each for programmer settings this would be amazing.
think near the compile to hex button a combobox with items as list with saved compiler configs
and the near the compile to chip button the same with items as list with saved compile fo chip configs.
that would extend the compiler settings in the config menue, and a user "click panel" on Top
without going to the compiler settings for selecting the saved setting if we want change
by using a other presaved or user saved setting
best wishes
rudi
combobox/listfield on toolbar for "compiler" targets
Forum rules
