FC7 Simulation Speed
Posted: Sun Jul 24, 2016 9:36 am
by Docara
Hello all,
I'm just playing around trying to learn how to use Interrupts on Timers, flashing LEDs, LEDs being on for so many minutes etc and switch inputs (interrupts)
I've tried ending the programme via decisions (if minutes =2) and also setting up the watch window but the simulation seems to be going much faster than it should be
Surely FC takes into account the proposed chip clock settings etc to give me the appropriate timings so how can tell if my values are correct etc if the simulation speed is so far wrong
What I'm saying is, when I programme a chip for real how can I be assured things will operate as intended if the I cant verify the results on screen prior to programming?
Matt
Re: FC7 Simulation Speed
Posted: Sun Jul 24, 2016 9:50 am
by EtsDriver
Hi!
http://www.flowcode.co.uk/mmforums/viewt ... 902#p75811
Could you use one topic, and try attaching flowchart there for us to see, so we can much easier help you. Your problem might now have some connection to each another on these two topics youve started.
