MIAC vs V5_MIAC macro
go233
Has thanked: 5 times
Been thanked: 11 times
Post by go233 »
I am using a MIAC example for communication between Labview and MIAC that has V5_MIAC macro.
Is it ok? I am using flowcode 6 and MIAC V2.
or do I have to re-write the program using MIAC macro?
Giovanni
Re: MIAC vs V5_MIAC macro
Hi Giovanni,
V5_MIAC is just the name given to the MIAC component when you imported the 5 project into v6. You can use as is without any problems and you can even rename the V5_MIAC name via the component properties if you wish.
