Strange Behavior
Posted: Sat Nov 05, 2016 9:38 pm
I have been developing this Fat ( Miro-SD ) read and Execute from File stored on
Micro sd , but at point I got stuck in this Problem which I think is a Bug .
When I try to read and exec commands only the first 1 will run , After
doing some investigation I found that the problem is in the String manipulation
maco -> Global_Str = Left$ (RS232_OUT,7) this works fine the first time it executes
but After that Global_Str will Have only the first 5 letters not 7 .
When Checking Global_Str length it display’s 7 although string was sent via rs232 and I can only see
The first 5 letters only .
I was Not able replicate this in a new file , happens only in my project so I have included the FCFX file .
