I2C slave
luibra63
Has thanked: 3 times
Been thanked: 6 times
I2C slave
Post by luibra63 »
I modify my old project for Crismtas. in this moment I use "arduino uno" card for master programmer realized with flowcode7 and it perfect work with 6 old slave cards realized with PIC 16F877 programmed in assemler.
for new slave card I use "arduino pro micro" but the module slave not work.
Is there a example for I2C slave module?
thanks
Has thanked: 481 times
Been thanked: 699 times
Re: I2C slave
Attached is an I2C Slave example.
Hope it helps.
Uno slave.fcfx
(6.21 KiB) Downloaded 286 times
luibra63
Re: I2C slave
Post by luibra63 »
thankyou LeighM, the error is my, I confused the address slave, now working.
When I must prefer I2C call of "Tools menu" from I2C slave of "Comms menu"?
thanks
Re: I2C slave
Thanks for letting us know that it is now working.
The I2C component from the Tools menu gives lower level access to the peripheral device.
So gives you the level of control needed for your slave functionality.
