Re: Possible bug in LCD generic component
Posted: Mon Nov 14, 2016 12:45 pm
It could be something to do with the way your clearing your buffer.
Maybe try a really simple program to print a fixed string to the display. This way you can check to see if it is the display or your program at fault.
If it turns out to be your program then maybe the circular buffer component would be easier to use rather than maintaining your own buffer.
